This Week on the Breadboard: The Bloody Germanium Overdrive
Chuck D. Bones
Circuit Wizard
This is something that HamishR & II have been messing with for a few days. It's kind of an an outgrowth of the ChuckMeister. It started with HamishR taking the 1st half of the ChuckMeister (he call his version the Shredmaster) and stacking it with a circuit we call The Beast. Then we started stripping it down and eventually ended up here. His final version is slightly different for this, but definitely the same flavor of OD.
Th name came from my Random Pedal Name Generator. I had to pull the handle a few time before I got a name I liked.
Knobs (L-R): LEVEL - BASS - TREBLE - MID switch - GAIN - FAT switch
Trimmers (L-R): Presence - Symmetry - Bias
The 1st stage is right outta the ChuckMeister, except I replaced one of the 1N4148s with a 1N34A. Next comes a Fender tone stack (minus the Mid control). The MID switch selects between a mild mid scoop and a mid hump. After that we have a gain recovery stage. The Bias Trim is a misnomer, a homage to EHX*. It controls how hard the 2nd clipper (D3 & D4) is driven. I used Germanium for D3 & D4 for the softer clipping they provide. Following that is the Presence Trim, a BD-2 type tone control. For the last stage, I selected an LM386. It provides gain recovery and can drive a mile of cable. The first stage will saturate during the attack if GAIN is set high enough. The 2nd stage can saturate during the attack if GAIN and Bias Trim are dimed. The last stage can saturate if all of the knobs are dimed, otherwise it runs clean. It's Marshall-esque in that we can get mild asymmetric limiting before the tone stack and some symmetric limiting after the tone stack. It's a medium-gain pedal that can make some tube-ish distortion without trashing chords, and drive an amp pretty hard if you want that. In the middle position, The FAT switch provides treble boost, like a Marshall's Treble channel. In the up position, the FAT switch lets all of the bass thru, just like the Normal channel. The down position provides some middle ground, like if you bridged the two channels. R18 & R19 skew Vref so that U1A will saturate more-or-less symmetrically. If you sub a rail-to-rail opamp like the TLC2272, then make R18 & R19 equal.
* EHX named one of the knobs on the distortion side of the Big Muff Germanium 4 "BIAS." It doe not affect the bias in the usual way, it it controls how hard the GE clipper is driven.
As Chuck alluded to this started when I ran my Shreddo (modded Shred Master) into the Beast (one of my fave ODs) and noticed how chunky the low end could be. I have always wanted an OD for my Strat which beefed up the low end in a way that kept the definition and Stratty twang. Not looking for loads of gain - although there sure is plenty on tap here - but more just a mega Strat sound. Can we get that in a single pedal? The Shreddo came close; this nails it. It reminds me of the tones Billy Gibbons gets with a Tele.
I had drawn up a convoluted schematic which I knew had way too many parts and as usual Chuck was a star and helped me remove a heap of bits which weren't necessary. I like this system - I have the stupid idea and Chuck says here's how we do it! He made it bigger and betterer but also more efficient and cleverer. My version is a bit simpler. On Vero it fits into a 1590B - just - and makes my Strat sound big and aggressive. Not necessarily pretty but I have other ways of achieving that. So with my Strat and a 1x12 Marshall style combo I can get things falling of shelves with the Crush (as I call mine) but still have a well defined sound with little fluff. The Shred Master's EQ works better than I could have hoped. Normally I wouldn't do EQ like this but it lets me get huge gobs of tight low end or reduce it to make my Gibsons almost sound thin. The bass control is very powerful.
This is mine. Chuck's is cleverer but mine fits into a 1590B on Vero and does what I want it too. I used an OP07 for IC2 because it doesn't need any compensating caps and I had a bunch of them. I am sure most dual opamps will work for IC1. I like hearing the clarity on the bass strings and generally use it with gain at or below 1.00. If this is a bit glassy or harsh at higher gain making C3 a bit bigger should fix that. 220pF should be enough.
I will build Chuck's version at some stage too.
*Edit* Just updated the schematic. Changes are minor.
How about making the mid switch an on/off/on as well and having another cap value beside C9 / 2n7, maybe a guess like 1n5 to choose from?
Probably more like an in between setting I guess. I'm not totally a fan of deep mid scoops. And just thinking because the fat switch is also three position, so why not...
This is the Tone Stack's freq response, from U1-1 to U1-5 with BASS at 7, TREBLE at 6. Green & blue curves are the current MID switch settings. I'm thinking about adding the red curve on the 3rd position. I'll let you know how it turns out.
In an earlier version I used a 1N4148 ad BAT41 in both clipping stages. It was a little harsh. Chuck used Ge to smooth it; I changed D3 & D4 to 1N4001s. Both work. I get tried of how easily Ge diodes break!
You're going to call it "Bloody Germanium Crush" and there's no Germanium in it? 🤬👎
But seriously, Schottky is a poor sub for Ge. At least put some resistance in series with the Schottkys.
BTW, my last version sounded like crap with the MID switch in the deep scoop position (green curve). Way too thin. The two notches in the v0.2.3 design are just right. I'm trying one more combo and if that doesn't cut it, then I'm done.
I think I've only broken one Ge diode in the dozens I've soldered into pedals circuits. Maybe you need a lighter touch. The bodies are generally longer and require a wider pad spacing than 1N4148. Something that certain board designers should keep in mind.
Yeah, "Bloody Ge Crush" 'cause it'll Crush all those Germ-in'm circuits. You know me, Dave, surreally serially not-serious.
Truly though, I might have some D9e to try, as I think my 1N34A on hand are suspect — I need to source some real legit ones.
For more gits & shiggles, I'll try some Schottky with series resistance (as per your suggestions) when I get this breadboarded — currently trying to make a variation of your FurBurger circ on the breadboard.
