Wiring Question: Two Circuits on One Stomp
jdduffield
I wired this up and later realized I wired the in and out grounds to the wrong jacks. The ground wire for the input jack is wired to the ground lug on the output jack and vice versa. (In other words the grounds are swapped.)
Is it worth the effort for me to rewire those grounds or does it even matter at all? The pedal sounds good. But I wonder if is still properly grounded. Please advise.
The grounds are fine as it is. Each ground is connected to each other so it doesn't matter where they go as long as they are all linked
That was what I thought but wanted to make sure, especially since I’m working w 2 boards. (But I knew that the grounds link via the dc jack and the center lug on the stomp switch. Just wanted to make sure I wasn’t missing something.)
