Deluxe MM board?
geezbill
i have a couple MN3005 BBD's. Are there any analog delay PCB's out there with modulation (like a DMM)? I know Madbean offers these but sadly out of stock for a long time. I wanna build at least an analog delay that uses 2 MN3005 for longer delay times.
This is the king of DMM. uses 3 MN3005.
I just built one, highly recommend. Mine is biased at 650ms. I 've tinkered with it up to 810ms but it's a bit wonky that high up. If you want a smaller box madbean has the skoolie board in stock atm.
The Aquaboy Deluxe with the modulation add on board from Madbean is another fantastic sounding analog delay. If I remember correctly it’s more similar to the DM-2 and Aquapuss. I had one at one point and it was one of the cleanest analog delays I’d ever tried.
The Skoolie (DMM in a 125B) is back in stock:
