Yes. Be sure to change R101 & R102 to 10K.Regarding the 10K trimpot between R101 and R102, do we lift the facing component leads of R101 and 102 to connect to pins 1 and 3 of the 10K trimpot and connect pin 2 of the trimpot to pan to the positive side of C101 for VREF?
The purpose of the zener between G & S on a MOSFET is to protect the gate against ESD. The only parts of the circuit that could be exposed to ESD once the box is closed are the IN, OUT and POWER pins. Q2 and Q3 are nowhere near any of those pins. Once Q2 & Q3 are installed on the board, they are safe from ESD events. Q1 connects to the input pin via C2 and as such is vulnerable it there is a static discharge into the input jack. D1 provides the necessary protection.What's the story with removing the diodes? Did they really have no purpose in the original circuit.
This is not a troubleshooting thread. Suffice it to say that my breadboard did not oscillate.With the WIIO pedal by itself I found I wanted to basically dime the gain, but when I did that the tone controls would cause oscillation above about noon. With the two drive pedals together I get a lot of choices about how much gain I want and the WIIO tone controls are more useful and don't cause oscillation.
I just picked up the version of the WIIO with the Post knob, and it sounds really good. I actually have on my pedalboard a Viceroy at medium gain going into this with the volume on the Viceroy boosted a little bit, and the WIIO also set to medium gain. Together they sound epic. (I'm practicing the solos for Comfortably Numb and need the sustain.)
Weirdly the WIIO doesn't like to be before the Viceroy -- it gets oscillate-ey as well.
Does any of this give any useful information about the circuit you're working on here? Happy to open up the WIIO and take pictures if you think that would be useful?
I seriously doubt it.It might have to do with the feedback loop that CDB attenuated in his mods...
No. Installing a JET necessitates either removing or reversing D1 because when biased into the linear mode, Vgs on an N-channel MOSFET is positive and Vgs on an N-channel JFET is negative. JFETs are not nearly as sensitive to ESD as MOSFETs, so I chose to remove D1. The JFET version will work fine with D1 in place as long as we observe the correct polarity.Did the rerouting of R1 to ground require D1 be removed for the circuit to function properly, then?
