tegendemuur
Via: https://spectrum.ieee.org/jimi-hendrix-systems-engineer
I obtained the schematics for each of these elements and their accepted parameter ranges, and converted them into netlists that ngspice can process (ngpsice is an open source implementation of the Spice circuit analyzer). The Fuzz Face pedal came in two variants, using germanium or silicon transistors, so I created models for both. In my models, Hendrix’s guitar pickups had a resistance of 6 kiloohms and an inductance of 2.5 henrys with a realistic cable capacitance.
I chained the circuit simulations together using a script, and I produced data-plot and sample sound outputs with Python scripts. All of the ngspice files and other scripts are available in my GitHub repository at github.com/nahorov/Hendrix-Systems-Lab, with instructions on how to reproduce my simulations.
Plotting the signal at different points in the chain with different parameters reveals how Hendrix configured and manipulated the nonlinear complexities of the system as a whole to reach his expressive goals.
A few highlights:
First, the Fuzz Face is a two-transistor feedback amplifier that turns a gentle sinusoid signal into an almost binary “fuzzy” output. The interesting behavior emerges when the guitar’s volume is reduced. Because the pedal’s input impedance is very low (about 20 kΩ), the pickups interact directly with the pedal circuit. Reducing amplitude restores a sinusoidal shape—producing the famous “cleanup effect” that was a hallmark of Hendrix’s sound, where the fuzz drops in and out as desired while he played.
Second, the Octavio pedal used a rectifier, which normally converts alternating to direct current. Mayer realized that a rectifier effectively flips each trough of a waveform into a peak, doubling the number of peaks per second. The result is an apparent doubling of frequency—a bloom of second-harmonic content that the ear hears a bright octave above the fundamental.
Third, the wah-wah pedal is a band-pass filter: Frequency plots show the center frequency sweeping from roughly 300 hertz to 2 kilohertz. Hendrix used it to make the guitar “talk” with vowel sounds, most iconically on “Voodoo Child (Slight Return).”
Fourth, the Uni-Vibe cascades four phase-shift sections controlled by photoresistors. In circuit terms, it’s a low-frequency oscillator modulating a variable-phase network; in musical terms it’s motion and air.
Finally, the whole chain became a closed loop by driving the Marshall amplifier near saturation, which among other things extends the sustain. In a reflective room, the guitar strings couple acoustically to the speakers—move a few centimeters and you shift from one stable feedback mode to another. To an engineer, this is a gain-controlled acoustic feedback system. To Hendrix, it was part of the instrument. He learned to tune oscillation with distance and angle, shaping sirens, bombs, and harmonics by walking the edge of instability.
A few highlights:
