Haible / Random*Source
The Tri-Chorus will be stuffed in my amp
Have you decided on how you implement the controls and outputs? I think I am going to just do the input, Low, Mid, High, and waveform as pots and toggles for chorus and modulation on/off. I think I will just wire one output. I don't think I need 3 different outputs. I am going with the 18v power option and use a wall wart for now At some point I may cobble together some sort of device that can power multiple 18v AC devices. I have a couple weird pedals that need 18v AC too.
Well, this depends on what I am going to hear when doing a typical stereo chorus (mono in, and a dry and wet channel out). That's my initial idea. On the legacy page he says that the whole effect falls apart when messing with the individual outs, so it feels like a waste of time. I will do the switches where you cut out one or two delay lines, as to get regular chorus and vibrato. And I feel like I should at least try to find out how to set rate and depth for each... Although I wonder if messing with rates within that trio of delay lines will screw things up in an unwanted way? Sure seems like it.
"Yes, we can do Stereo, with the individual outputs. My first thought was to take the 3 individual outputs and mix them, one panned left, one center, and one right. But then the "Ensemble" effect falls apart, and the modulation sounds overly strong. I think you cando a lot of experiments with mixing the individual outputs, and will find interesting configurations."
Considering there are a few of us building out Tau Pipe Phasers, I've started a 'joint effort' "Tau Pipe Phaser V1.02 Build (Joint Effort)" thread in the OPEN DISCUSSION forum.
I've not found any info on the web related directly to the Tau Pipe Phaser v1.02. I plan to take some reference photos and pics of sections of the build as I go. We can put our heads together for parts sourcing, connection issues, housing, etc.
Considering there are a few of building out Tau Pipe Phasers, I've started a 'joint effort' "Tau Pipe Phaser V1.02 Build (Joint Effort)" thread in the OPEN DISCUSSION forum.
Definitely!
My NOS is very similar, except for DIP instead of SMT and the lack of the slow switch (which is basically adds a cap). So yeah, I'll be there!
It's still three large-ish orders from different companies before I got everything at home to finish them though, so don't be shy to start before me. 😅
Same for Krautrock. But
