NAM A2 Raspberry project
this is very cool. Been following quietly. Any thoughts on midi integration? It would seems someone likely to use this, especially a stereo setup, would likely have midi capability.
even just a simple program/preset up down and/or preset follows CC would be cool if there are open pins to utilize.
MIDI is definitely on the list! Probably next week or week after though. The stereo amp thing takes a little more time to finish.
And main focus was that I wanted a nice and user friendly UI, which I believe none of these projects above have (I might sound harsh here a bit, but this criticism is coming from 20+ years of experience in software development - I do this every day with awesome designers). And since A2 is so easy to integrate, why not try to do a project like this?!? Also open sourcing it was very important to me, with easy to get parts, so you don’t have to buy a PCB from some guy on the internet. I’ll just upload the files and you can get a JLCPCB order and job done.
Heard - my other field is working in web UX design/development, so I get the interest in being able to spec your own implementation. Was mentioning the existing software frameworks more as a proof-of-concept starting point than a finished product, or something to borrow from to get going. Interested to see where you take this!
Stereo mode is a huge bonus in what passes for my world. As soon as I can clear out my obligated work queue I'll be all in.
Don’t get me wrong please, but I felt like those projects are not up to the quality I had in mind. Not necessarily talking about the sound of course, but the “packaging” that they are coming in. None of these have a touchscreen, which I wanted to have, since there is so many different ways you can to set the effects.
I liked the PiPedal project, but having a USB interface was something I wanted to avoid.
In mind I had a simple idea: touchscreen, 4 footswitches, master volume encoder, that’s it. Oh and in one enclosure -> no external USB device and that sort of thing.
Oh btw I committed some very important performance updates to the DSP code and tone3000 integration in the desktop app.
I am currently working on dual amp stereo chain setup, very close to finishing it!
I had the first gig with it this weekend and the mono version worked very nicely even in a junky 3D printed enclosure.
Any plans to add compatibility for an expression pedal? I won't look too far into it if it's already on your roadmap.
Actually I haven't thought about it yet, but it is a good idea. Not sure when I'll have free to do it but feel free to share details, what would you do with it?! I am not a huge expression pedal person so any potential use case will help me plan this.
Just thinking about digital effects that could be imported: pitch shifters, feedback pedals, rotary simulators, wahs...etc. Having some ability to control those apart from the UI would be cool.
I’m a big fan of mapping an expression pedal as a macro control. Set expression to heel, adjust patch parameters. Move to toe position, then adjust parameters again. Moving the pedal should transition between these two states.
A map to midi with a learn function could be cool. Hook up one of those giant behringer midi foot controllers, load up a wah effect, hit "midi learn" or whatever, tap the wah position "pot" on the unit, wiggle one of the pedals, hit eave, now it's synced.
Or, midi learn with advanced mode.
Complete action as before, but before hitting eave there's another button "advanced" or edit or whatever. Touching it opens a sub menu. this allows you to set the range of the control. I.E. if you tapped "feedback" on you delay "pedal", you can then set the range of which the pot is controlled with said footpedal. If it's a physical button/footswitch, this you set the two values the switch would toggle between.
The sliders could be labeled 1 and 2. when the preset is loaded, it defaults to setting 1.
This could allow sub-presets. one stomp and you boost comes out of bypass, you chorus bypasses and the gain pot goes from noon to 2 o'clock.
Using a simpler controller, like the m-vave chocolate, which is a simple 4 footswitch midi controller, would give you quite a bit of flexibility. 2 switches for preset up and down. 2 more for alternate "scenes" within the same preset.
IDK, an idea. I'm just getting into midi with pedals but the learn functionality has been around in DAWs for decades.
Some updates: Stereo chain works fine now, UI is polished a bit.
If anyone other than me assembles this project, give me feedback, please test it if you can, as much as possible and beat the shit out of it, break it. Critic me any way you can. I would love some constructive criticism.
I uploaded some 3d printable enclosure files (I currently use these for prototyping), this will get updated with MIDI, expression pedal, etc...
Bottom lid can be attached if you are pressing heated M3 threaded inserts at the corners.
Also took the Terrarium buffer, made a small Kicad project and simple board that you can use between the guitar input and the Raspberry Codec Zero: https://github.com/balazsbencs/ardor/tree/main/buffer
It's all surface mount stuff, so JLCPCB CSV files are included as well.
I added a global settings screen, so you can change color theme, also have your home wifi set up (since the desktop app works through HTTP for models and IR uploads), that is easier to set up now.
Also added a noise gate, could be useful for a lot of people.
Started working on MIDI and expression pedal input!
Hello!! I`m super interested in this project though i don`t have a clue about coding. I was looking at this Raspiaudio https://raspiaudio.com/product/8xin8xout/ as i would like to route my pedals and effects in and use the NAM A2 only for amps etc. Would that work? Also i would like to have a headphone out and midi as others have said. Thanks for all your work!! Be well!!
Cool! This is one of my shared basic gain stage boards that I use in onboard bass preamps and EQ and delay pedals: https://oshpark.com/shared_projects/G9QIFzFZ
It uses an SOIC-8 opamp and 1206 resistors, so hand soldering is fairly easy. The caps are all through-hole on this particular board, but easy enough to adapt to tantalum SMD or whatever. I've had especially good results using the OPA1641 opamp but many other singles will work fine. Trim pot for gain on this one, but other versions have breakouts for an external pot. Happy to do a stereo version if anyone wants that.
I'm still a couple of weeks out from jumping into your project, but I'm really looking forward to it!
I'm about to send the gerbers away for the buffer at JLCPCB, but you reminded me that I really need to need to revisit your bass preamp circuits at some point.
Was going to build up your original from years back but it didn't go anywhere so I figured I should use your latest design.
I'm about to send the gerbers away for the buffer at JLCPCB, but you reminded me that I really need to need to revisit your preamp circuits at some point.
And in turn I really need to get a few more of them up on Github. But as usual, doing the documentation can be a bit tough to get motivated for.
Basic MIDI control is working for switching banks and presets, also I have basic Expression pedal assignment and input.
Since I need an ADC circuit for the expression pedal, this feature is not going to be supported without extra hardware. I will do a circuit (or if anyone wants to draw up a circuit, feel free), using a ADS1115 would be enough for this I think.
So software support is ready, but I think I'll have to do a full featured PCB with the buffer and the jacks soldered to the board and also have the expression pedal input, everything..
Oh and also what do you think about Expression assignment and MIDI Learn like this?
I think it's going to work great, but I have no MIDI pedals at home right now and I haven't finished my superduper midi pedal project yet. (MC4 pro clone is coming!)
I think I'll slow down with new features now, focus a little bit on documentation, let's have a nice website built, finish up PCB designs for expression pedals.
:cautious:If you're ordering boards from jlc, got one I can buy off you once they come back? :)
