As I have mentioned here recently I had a friend's pair of '62 Fender brown amps to repair in my workshop. The brown Super is remarkably original. It had a replaced PT which seems to be quite common but the board appears completely stock other than the electrolytics which have obviously been changed and I updated also.
But as I installed the 240V PT and connected the new 3-pin power cable I discovered that the fuse had been completely bypassed. It looked like it was connected but one end was completely disconnected, hidden by wire. So that was alarming! What kind of idiot bypasses the fuse??
All the PT grounds had been removed from the chassis solder blobs and attached to the PT mounting bolts via eyelets. Now I understand that this is a bad idea because the PT nuts can work loose so all of those connections are now back soldered to the chassis with my big heavy duty iron.
So now the amp is safe and runs even quieter than before. It's amazing how quiet an amp can be when it's grounded properly.
