String gauge what are you using?
SillyOctpuss
After getting my new tele back with the 10-52 strings I requested I was a little concerned the first night I was playing it. It all felt a bit rattly and the strings were a lot floppier than I would like, so I bought some 11s threw them on and they totally transformed the guitar. It suddenly felt like I was expecting it to originally and sounded a lot better too.
I was a little hesitant to try 11s as I use 10s on every other guitar I have including my strat and my other tele. There's no dought though that 10s were just too light on this tele. I wonder of it's the huge U shaped neck?
So what do you all use on your guitars? Do you stick to 1 gauge like I did up until last week or do you put different gauges on different guitars?
9s on teles, 10s on Les Pauls, although I was just thinking last night I wanna put 10s on my main tele. Didn't we have a thread about this a few months ago?
@SillyOctpuss here's a link to the other thread if you're curious. No worries on doubling up! It's easy to miss stuff with so many active participants here
Thanks I completely missed that thread
Wow that would definitely be too low in tension for me. What scale length is that on?
25.5”
I do have 11’s on some guitars, but only the ones where the thicker strings sound better on that guitar.
I just think thinner strings tend to sound better, especially for low tunings. I mostly play 7 strings down one step in A-standard (just D-standard with an extra low string), using 10-46 with a 60 for the low A.
I find strings will ring out of tune much easier if there's not enough tension and I hit the guitar hard. I'm going to try it on my les paul at rehearsal on Thursday night at band volume
I was doing this in a band too, and we played (probably too) loud. Seems to me like lower string tension gets a better "aoouww" sound when sustaining notes, and I almost always pulled my power chords down while strumming
My main gigger is .090 — .122
What's really weird is the D is thicker than the A.
I was using a solo set bumped down to regular tuning, don't know the exact gauge, but in millimetres it's roughly 1.1mm — 2.4mm.
I use a lot of different strings depending on the instrument. Just to list a few:
Les Paul: custom assembled set (flatwound) [9-12-17p-28-36-48] (note: wound strings are Daddario chromes, plain are Daddario plain steel)
Strat: Ernie Ball Super Slinky [9-11-16p-24-32-42] or Daddario NYXL super light [9-11-16p-24-32-42]
Epiphone Casino: custom assembled set [10.5-14-18p-28-38-52]
Fernandes PJ: Labella 750N Black Nylon Tapewound Light (Long Scale) [50-65-85-105]
Can’t think of any of the others off the top of my head. Some guitars I go as low as 7s on, and others I go as high as 13s for standard tuning. Acoustics are mostly 14-60 tuned down to C# or 12-52 in standard
