Aion FX Aperture & Azure Combo
teegle
Hey guys,
I finished up a combo build last night and had a couple issues.
1. The fuzz doesn't do anything. The pedal works in bypass but I activate the fuzz and there's nothing. I tried toggling the boost switch and turning knobs but nothing happened.
2. The chorus worked the first couple times I tested. Then I reflowed some joints on the fuzz and the chorus stopped working. Went back 20 mins later and the chorus was working again but the fuzz still is not.
3. LEDs both work, signal is fine when both effects are bypassed or when the chorus is on.
I don't have a lot of experience troubleshooting so I very much appreciate the help.
Another thing about this build, it has an effect order toggle switch between the footswitch PCBs. I am very confident in the wiring side of things.
