"That" Compressor: Dipper Compressor (w/Gerber)
rwl
5.00 star(s)
This is a report on Dylan159's "That" Compressor. It looked like an interesting circuit to try putting on a PCB, so I figured I'd give it a shot. I don't know what I was thinking - great idea to put a compressor on a custom PCB when you're the kind of guy who can barely tell compressors are on! That said, I think it's a pretty solid compressor - I like it less than my General Tso build, and more than the AionFX Oceanid. Maybe I'm just saying I like it less than a compressor I can hear compressing and more than a compressor that introduces a bunch of background noise. Many of you will be gratified to learn that it doesn't have a blend knob.
Since I laid out the PCB, you can download the gerber file here.
Inspiration
Well, the connection between the bird and the pedal is a bit of a stretch. Dylan159 describes this as a compressor with "very low ripple," and there weren't many other descriptors, so I decided on a diving bird, and I figured that an American Dipper would be a fun one. Dippers are the only diving songbirds. Although they're a little boring-looking, they're also super cool. Here in the Pacific Northwest, you can find them in the Cascades, diving into mountain streams for food. It's the kind of bird I probably never would have looked for or noticed before I started birdwatching. It's really disconcerting to see a bird that looks more appropriate for hiding in a shrub standing on the rock in a middle of a rapids and diving into glacial runoff. You can see that they look a bit like a robin or a large wren than a waterbird.
I'm pretty proud of the concept here. American Dipper - how to make it into a pedal that's more than just a dull-looking bird standing on a rock? Why not mix it with the "Big Dipper" and make a constellation? The shape of the Big Dipper is surprisingly similar. So I decided to go with a star-chart theme from astronomy books I had as a kid, and I'm pretty happy with how it worked out. I have the Dipper holding a little minnow (to be honest, I don't know if they eat minnows vs tadpoles/larva/etc). The stars in the constellation, including the fish, are all in the positions of actual stars if you stargaze near the big dipper, but I connected them to form more of a bird outline and truncated the Big Dipper's "handle" since the American Dipper has a stubby tail.
The overall effect looks very good in my opinion. I only wish I remembered that dark colors on Tayda prints tend to be a little too dark - I would have boosted the colors slightly. And the knobs are great (aluminum Davies 1900H knobs from Tayda). I think these are my favorite knobs right now, they feel very durable, have a nice coolness and heft, fairly bright colors, relatively cheap, and small diameter to leave more space for artwork.
The Build
A straightforward build. This was an early PCB layout for me and I think it turned out well. As with other Dylan159 builds, the components are all easy to source. The PCB worked on the first try and I had no problems with the assembly.
The Pedal
It's a compressor. It definitely does something, but it's pretty subtle even with threshold at a minimum and ratio maxed out. It's more subtle than the General Tso. It also has a built-in boost capability (the "Makeup" knob, which is intended to compensate for any volume loss during compression), which I think is a nice extra touch. The main problem I have is that even with Makeup turned down, there's still a subtle volume boost for me. So it's hard to turn the pedal on and off and to hear just the compression on its own.
I wish I could give the pedal a higher rating. It seems like it's a subtle compressor that subtly compresses, but that's just not very exciting to me.
Firsts
  • 🌠 First stellar pedal
Build rating: 5/5 ⭐
Pedal rating: 3.5/5⭐ (more a reflection of my opinion of compressors than of the pedal)
Stellar build!
When they first came out, I wasn't sure if I liked the alloy 1900s based on product-pics (not on pedals), but they look fantastic here. I'll have to get some.
Many thanks for sharing gerbers!
Too bad it's a comp that you won't likely be using.
I might use it - I have two pedal boards at home, one for the basement and one for upstairs. And now I have two compressors I don't mind using (I really didn't like the Oceanid). I also have the Aion Quartz, partially built on my workbench. But I'm not likely to build another compressor after these, so I'll probably just stick with this and the General Tso if I want a compressor on each board.
Yeah, they're really clean and feel professional. I'd recommend them.
