SOLVED Byzantium Flanger no Hz at TP1
mkultra69
So I got the pedal built and it seems to be working just fine, never had a flanger but sounds good to me. Went to check what the Hz was since Ive seen on here that should be set to 40 kHz but I get 0. I have never had a need to use the frequency setting on my meter but seems pretty straight forward. Ground 1 probe test with other, any thoughts? Do you have to be passing a signal through the pedal while testing?
as per this guide:
1.) Clock frequency adjustment:
Set MANUAL and DEPTH knobs to full counterclockwise. Connect an oscilloscope to TP-1 test point. Adjust VR7 for T=25us (40kHz). Rotate the MANUAL knob fully clockwise. T should be 2uS +/-20%.
obvious ones to check:
- make sure the ground lead of the meter is connected to circuit ground (e.g. input jack sleeve is usually the way to go), meter set to [Hz], ensure the probe is making contact with TP1 pad.
also, which chip are you running in IC4? (should be V3102 or MN3102)
not necessary for measuring clock frequency at TP1.
Well, turns out when I said I have never needed to use the frequency setting on my meter I should have gave the manual a quick peak. Turns out my Fluke doesn't read Hz through the probes, it reads it through the amp clamp. 🫠 Got the cheapest meter I could find off amazon and yeah ever thing working as it should. 👍
