This Week on the Breadboard: The ChuckMeister Distortion
Chuck D. Bones
Circuit Wizard
Ok, I'll admit that it needs a better name.
HamishR & I were playing around with the Marshall ShredMaster, trying to make it into something a little different. You'd think that a pedal with "shred" it its name would be a high-gain pedal. Not the case with the ShredMaster. For us, the best part of the GAIN setting range is at or below where the opamps start to saturate. So that's where we focused our attention. Stripping out one of the opamps up front was a no-brainer. Next, we tackled the tone stack. I started out with a stock ShredMaster on the breadboard and I could not find tone knob settings that I liked. So I chucked (pun intended) the SM's tone stack and started over. Here's where I ended up. It's 90% there, sounding really good with Humbuckers. I have one more tweak I want to try.
Knobs (L-R): LEVEL - BASS - MID - TREBLE - GAIN
Basically, it's not much more than a Distortion+ with a 3-knob EQ. This circuit provides a smooth edge-of-breakup tone. Chords ring clear; you can hear every string. All of the tone knobs work independently, very little interaction. TREBLE & MID are cut only. BASS is boost only. The flat setting is TREBLE = 10, MID = 10. BASS = 0. The Mid Cut is centered at 500Hz. The Bass Boost can recover some or all of the bass lost in the first stage. I skewed Vref a bit so that U1B will clip more-or-less symmetrically. Last thing I did was add R7. R7 causes mild asymmetric clipping in the diodes at moderate signal levels and really improves the tone IMHO. R7 is a 1K trimpot on the breadboard (not shown in the pic above). I have it dimed and it sounds great. The only thing left to do is try it with my Tele and see if it needs a FAT switch.
I've got a SM board on the way so I'm curious, what was so wrong with the tone stack that made you scrap it?
One thing I really admire about Chuck is how generous he is with his time. He is extremely patient with me who knows nothing about electronics! But I love coming up with my own tweaks and Chuck has been incredibly helpful and some of what he has taught me has stuck, even if only a little.
I like to simplify and agree with him that the tonestack is not that great. I have always found the contour control sucks. At around noon it's fine, any lower is ok but not particularly useful and higher it's that awful massive midscoop that makes your guitar magically disappear onstage. Getting rid of that allowed us to remove an entire IC. I don't mind the remaining tonestack once modified a bit. This is what I ended up with. Modest compared to Chuck's (which I will definitely be building) but it's a very useful Marshall-flavoured OD. It's a lot clearer than the original and you can indeed hear every note in a chord, while remaining quite ROCK. I particularly like it with a Strat.
@HamishR couldn't agree more about Chucks legendary generosity and celestial knowledge.Your write up makes me even more itching to whip up a board for this.
I did end up adding a FAT switch. In the middle position, it's just like v1.2. In the down position, it fattens single coil pickups for a more balanced tone. In the up position, all of the bass gets thru for a nice thick tone, even on a Tele's bridge PU. No need to turn up the BASS knob when the FAT switch is up.
Once you've played thru one, you'll know. It's possible that retuning the tone stack and CONTOUR circuit could produce a better tone, but after a bit of fiddling I got frustrated and concluded that there had to be a better way.
Keep in mind that this is not a modded Shredmaster. That may have been the starting point, but it was not our goal.
