Nerdridesbikes
I am building a complete diy amp less bass board. It’ll run through a nobellium at the end, as I mostly play clean. I want to add in some grit occasionally and fell in love with the SGFX Beta V in the low gain settings where it adds a bit of growl. I will have other pedals for higher distortion. The answer is probably just to buy a Beta V but I want to build my own. Can anyone recommend a pcb that’s similar in the low gain slight distortion? I liked the sound with the LPF off if that helps. I was considering a Vintage microtubes, but it tends to have a lot more high end than I’d like. Any suggestions would be appreciated. Edit: to clarify I am looking for something that is “always on” depending on the song or gig.
