Spatialist Reverb
GazM
5.00 star(s)
The last one (for now) of my board themed around my favorite artists.
I made a massive error on this build, where on auto pilot I soldered the rotary switch on the wrong side (Idiot)! one ruined rotary switch and much annoying desoldering later, its now complete! really happy with how it sounds, still need to play around with the settings on each mode, but sounding great so far. I got the FV-1 pre-soldered as I didn't want to attempt that.
UV printed design on matt black enclosure from Tayda print service. I noticed that at this scale, some detail is too fine and so need to increase size of text / lines in the future.
I've got this on in my queue. Does it sound "authentic" for reverb?
Nice build!
You have to bear in mind I only finished it yesterday, but have been having a play today and I think it sounds good. However, its not up there with some of the professional reverb pedals I've purchased before. I think though that may just be a case of spending more time dialing it in, so probably (highly likely) user error. I need some more time to play about with the settings, but one thing that's also tricky is that the 3 control knobs have different parameters for the different effects, so remembering what they do is hard, probably need to print a cheat sheet. I can't really expect the pedal to rival what I had previously (Walrus Audio R1 / tone master pro etc) but I think with some more time I will be able to get it close. Worth building for sure!
