Circuit explanation help
Toastman
Hello, I know I am probably asking for too much...
But could someone explain to me how this circuit works and what each part does.
I have an general idea, but I would like to know exactly.
Thanks in advance :)
I am not in position to explain everything, but i found the circuit analysis of electrosmash useful to understand the basics.
I also saw some vids of Brian Wampler on this topic.
Very helpful link
It's nothing like a Fuzz Face or Big Muff. It's a rather unique circuit.
Q2 bootstraps Q1's collector via R4, except when GAIN is dimed. Boostrapping effectively raises the impedance of R4 which increases Q1's gain. Q3 loads Q2's emitter. At low to medium GAIN settings, Q3's input impedance is fairly high and the loading of Q2 is minimal. However, when GAIN approaches 10, Q3's input impedance drops significantly which loads Q2 and weakens the boostrapping effect. Max gain is around 55dB at 1KHz.
Q1 & Q2 run right at the edge of saturation. Q3's biasing results in asymmetric clipping for most signal levels and GAIN settings. We can improve the symmetry by reducing R6. If we want to add a BIAS knob, we could replace R6 with a 1K resistor and a 10K pot.
The TONE network is a bridged-T notch filter. It creates a broad scoop centered at 1.7KHz that affects mid and treble frequencies. Maximum notch depth is around 8dB.
Is that enough detail? I don't go part-by-part, but I do describe how it works.
