MichaelW
- Build Rating
- 5.00 star(s)
Continuing on my build report catch up.
This is the second channel of the discontinued Cornerstone Gladio, which was a dual channel OD with a Timmy based circuit on the first side and a Zen based circuit on channel 2.
Channel 1 is available from @Robert as the "Scenario Preamp". Which is cool in and of itself as it's a Timmy with a clean blend. But I digress.
Ch1 is supposed to emulate the Dumble SSS and Channel 2 (this pedal) the Dumble ODS.
As such it borrows heavily from the "industry standard" Dumble-esque circuit the Zen drive.
There's a couple of toggles, one of which drops the clippers for an op amp drive. The other is an EQ toggle that emulates the "jazz/rock" switch on an ODS.
Otherwise it's pretty much a Zen, albeit a very nice variant.
Highly recommended build if you like the Dumble sound. It not surprisingly pairs very well stacked with the Scenario preamp.
I built this one with one of @szukalski 's micro relay boards.
