I know that these things are notoriously tricky to dial in, but I’ve got some issues with this that I haven’t read about in other threads.
Most of the time it doesn’t pass any signal, but at certain settings it’ll almost work for a second if I hit the strings hard. If I turn the mix down it allows the dry signal to go through, and the boost works.
Any thoughts on this? I used another presoldered J201 instead of the 2SK208-Y, but other than that, all the parts should be correct. Another set of eyes would be appreciated just in case I did something dumb like install a component backwards or something.
