Audandash Well-known member Feb 19, 2026 #2 I will give it another few days to see if someone has it. If not I will work on one for you.
Audandash Well-known member Feb 21, 2026 #3 Here you go. As always I would double check with the actual board but this is based off the template in the build doc. The power is the smaller lumberg style and the led is 5 mm. Tayda Electronics Drill Tayda Electronics Drill Designer for custom enclosures. drill.taydakits.com
