Dielectric Boost build
analog_bham
5.00 star(s)
Wanted to give a Tchula a try after watching Josh Scott’s Short Circuit series.
Had in mind that I wanted to keep its appearance the same as the original for no real reason. In hindsight this made it so much more difficult than it needed to be because the PedalPCB switches are reversed from the original pedal.
Got it done and really like the sound of it. I built it with carbon comps and tropical fish for no reason other than the fact that I like them aesthetically more than other types. Definitely see this one going on the pedalboard.
It was a tight squeeze with the chunky board and the way I chose to orient it in the 125b.
I have the je t’aime on the breadboard right now. Will house it up later this week
That's cool! I did the same thing with mine, making it horizontal. You can make the Je Taime into a tchula if you want to fit it into a smaller enclosure.
Also, there is the Twill Deluxe, which is a Les Lius. It has 3 modes, one of which says is a tchula but it's a bit different. The Thchula is my favorite low gain drive. It's so nice
