Kliche Mini SE (Klone Trooper)
5.00 star(s)
I wanted to make this one look a little nicer and quickly had this Star Wars-themed idea in my head. I tried using a waterslide decal for the first time. I ruined the decal in a couple spots during final assembly using pliers to tighten nuts instead of a socket (oops), but I still like the overall look.
If you look closely, you'll see I accidentally swapped the leads to the input jack. That was disappointing when I first plugged it in, but I figured it out pretty quickly. The pedal sounds fantastic, especially when stacked with the Mach 1.
