Champ Amp 2 Prong Replacement And Others
joelorigo
I have my father-in-law's 1966 Fender Champ amp. At some point the original 2 prong was replaced with another 2 prong. I have been wanting to use my pedal building experiences into building an amp someday and I was thinking about removing the "death cap" and replacing the current 2 prong cord with a 3 prong cord, and maybe some other things might be a good way to start. I was going to start with a tweed Champ or Deluxe kit but I don't have the money right now.
I have seen Psionic Audio and Uncle Doug videos about old Champs and they are also talking about replacing the "bias resistor" with a higher value to compensate for modern wall voltages. Changing the "mids resistor" to combat the inherent boxy-ness. Replacing the "filter cap" and "cathode caps." (BTW I know what these things are only because of the videos mentioning them and pointing them out were the are on the turret board, lol) Replacing the SPST switch with a DPDT. I was also thinking of replacing the RCA speaker jack with a 1/4" to make it easier to use external speaker cabinets. Really I just want to replace the power cord first so all these other things could come later. I also have a 1975 Fender Bronco so I would think all of this would apply to it as well (although it has a 3 prong cord already).
Do any of you with amp building experience recommend / agree with these mods, and have good resources you can share?
1. 2 prong to 3 prong and remove death cap — yes, very much yes.
2.
Bias resistor? Maybe. You’d have to check what your voltages are inside the amp (SAFELY OF COURSE) to determine if you need to adjust bias. BUT, the 6v6 is pretty robust.
Mids resistor? Maybe, but that’s the charm of Fender amps
Filter caps? Maybe, depending on age. If the amp hasn’t been played in a while and has some buzz, might be necessary (get good quality but don’t overspend on super fancy).
Cathode caps? Not likely, replace maybe. Again, changing the value will change the voicing.
1/4” plug/jack for external cab? Heck yes
3. Reading material —https://robrobinette.com/Amp_Stuff.html
2.
Thank you!
Thinking the bias resistor couldn't hurt. Friend of mine uses a 60's black panel Princeton reverb with this little gizmo and has made a world of difference. Brown Box .
