Aside from the switch, this is one of the easier builds once you master mounting pots and switch in the inverted case to line them all up before soldering them in. I have a photo of that stage of the build below, along with the finished pedal (with the Gain switch mislabeled as 'Clip'...
I went for Asymmetric clipping as this drive has a very neutral EQ and I needed to get some clipping in there to feel the love.
If you are planning to build this one, be aware that the drilling template for Tayda which is found on this site isnt exactly the same as the pedalpcb drill layout in that the Tayda file has an 8mm hole for the bezelled LED and I was expecting the usual 5mm. So I ordered some bezels.
