PedalPCB Mini Muffin Fuzz/EHX Muff Fuzz - with muffin crumb amplifier stage (tone recovery stage) 1590a
OD is Glorious
5.00 star(s)
Thanks to @Feral Feline for the advice and direction for making use of the Muffin crumb amplifier stage (MCAS). I messaged them after seeing this thread about Muffin Crumbs. The Mini Muffin Fuzz is notoriously underpowered with unity at fully cranked. I previously built one and it was weak. I wanted to add power to this 1n34a Ge based fuzz and the MCAS worked perfect. I also have to also thank @Harry Klippton for directing me to his thread about how to better put these circuits in 1590a enclosures. I was putting jacks above the boards and using side D.C. jack before seeing HK's thread. That HK thread motivates and inspires me to do more than just one-knob 590a builds..
I am including the values I chose for the MCAS. It do not see that anyone ever listed values anywhere so I copied the tone recovery stage values from here. I successfully breadboarded this circuit to create a tone recovery stage. You can see in the image that I put the whole Mini Muff board right on the breadboard so I did not have to breadboard that circuit. (not sure how to breadboard the IC - 4558 ...yet). Note that I did not have a BC239 so I used a BC549c. Also I started with a 10k at R1 and then I changed it on the breadboard until I found the sound I wanted. I settled on 8k2 because to my ear, it sounded slightly more punchy. With the amp stage installed unity is now at 3pm so it is still not overpowered, but I am satisfied that I have somewhere above unity to go!
It had great results. I insulated the low profile footswitch's breakoiut board and the solder side of the MCAS. I also mounted the caps on the MCAS very close to the board. I also used Lumberg jacks and I made use of the PPCB D.C. breakout board so I could add power to the MCAS.
I am very happy with the result.
GREAT JOB!
If you need a recovery stage again in a future build, you can use
2N3904
2N5088
2N5089
Well, a LOT of different transistors would work well, too many to list, but the BC549C you have in this one was/is an excellent choice.
