Micro buffer build
Vild
5.00 star(s)
Works great.
I should probably start wiping off the flux before I post pictures.
Some notes that may be of use.
I used the 125b enclosure drill template to help me find good spots but your mileage may vary.
I soldered the led after it was already in the hole and board screwed in.
I could have probably done something similar to help center the power jack better or just drilled the hole a little lower than the other jacks but it works with my cables as is.
