Yeah my early tests with chatGPT a year ago to write the optimizer code were a waste of time. I started using Claude at work and tried that on the optimizer and it knocked it out of the park. I've used Claude quite a bit since then for a variety of things, and sometimes you get lucky and it is able to figure everything out just from prompting about the desired end result. If it starts going in circles you'd better know what you are doing underneath though, because it has a tendency not to admit it doesn't know what it's doing.
Anyway I'm glad you are getting some use out of SpinCAD. I'm probably going to set up an Easy-Spin pedal with some Mary Halvorson patches on it for my experimental steel guitar pedalboard (think "Fear and Loathing in Waikiki") and be done with the FV-1 for the foreseeable future.
I got a Chaos Stratus pedal because I wanted something I could program in Faust that was an actual pedal rather than a Raspberry Pi. That one offers AI programming as part of its ecosystem. I tried it once with a pretty specific request and have no idea what the end result did - nothing as far as I can tell. That company seems to be one or two guys in their spare time so getting help is hit and miss. And the guys at AudioFab who make the Easy-Spin FV-1 pedal built up a development tool using VS Code which also offers a means for AI prompting which I haven't tried. I've always wanted a "lush, transparent aliaser" though... maybe I'll give that a shot.
Much as I'd like to take personal credit for the improvements to SpinCAD Designer, the grunt work was done by Claude and in a few cases I'm sure I had to help it attend to some nuances. It's pretty fascinating and simultaneously unfortunate that this particular "advance" in software development appears to be having a negative impact on many people's lives, directly or indirectly.
As always, don't hesitate to ask questions about SpinCAD one way or the other.
Cheers,
DL
