Op Amp Static Troubleshooting
jdduffield
Hi,
I’m trying to figure out what type of noise this is so that I can try to fix it. Does anyone recognize what this is?
See video:
Maybe DC voltage getting on it, or maybe high frequency oscillation? I don’t know enough about what I’m listening for to diagnose.
This is a design I came up with that works on a breadboard. See schematic attached. I’m trying to install it into a pedal.
I’ve ruled out a few things. The op amp is fine. I’ve tried swapping it and no luck.
It is a TL072. Using two non-inverting gain stages. First stage is fine (using pin 3, 2, and 1). Stage 2 has problems. Pin 5 sounds good. 6 sounds good. But 7, the output, sounds bad.
I’m getting 4.5v on vref, so my voltage divider is working.
Tried a few things, like adding a 47p cap across pin 6 and 7. Didn’t help. Seems all is well until the circuit gets to pin 7.
Btw - pin 8 has +9v as suggested by the schematic. Pin 4 is grounded.
I’ve been reading through this forum and some of the materials you all provided and am redesigning the circuit. Thank you so much for your help. It is sounding great so far!
