MiniMe Plus & Caesar Chorus
Two Chorus builds. GuitarPCB's Mini-Me with Wilkie's "roto-tone flangery" mod and rate cut mod (I believe per @Cybercow ?) to try to get into Rockman chorus territory. Everything fit in the box OK, but I should have either moved the boards slightly lower or used a deeper box than a standard 1590BB......a little tighter than I would like with the jacks. My first try using a rotary switch, and I wish someone would make a beefier (metal) rotary switch that would do a full 360. Also a PedalPCB Caesar Chorus with the combined blinking LED mod. I haven't had time to play much with either let alone do a side by side, but both sound great with lots of tweak-ability. Thanks again to members for guidance and inspiration.
Lumberg jacks would likely have provided you more wiggle room in there, but so far as I'm concerned, you made the right call using a 1590BB. Their lower profile makes for some of the best-looking pedals around... and yours looks good.
Lack of time is my problem now to do anything pedal related for more than a couple minutes at a time. The Mini-Me really does sound great with the clean 1 & 2 Rockman EQ's, but I haven't had time to do a similar test with the Caesar. I also just ordered a couple Lumberg jacks to try in a future build.
