OD is Glorious
- Build Rating
- 4.00 star(s)
Essentially this is a very high gain distortion pedal that does sustained fuzz. I can confidently call this a fuzz pedal or a distortion pedal but I would not classify it as an overdrive. Tsk tsk Mad Professor... false advertising. The circuit has too much gain – too much sustain - just not the sort of circuit I would call an overdrive. This circuit brings soothing aggression! I will admit the tone is decent and the circuit produces rich harmonic distortion. It gets dark and low when you want and when you dial clockwise your signal will get highly saturated distortion and compression with seemingly never ending smooth sustain.
No op-amps but it uses six transistors. Some oddball parts but I had everything except the oddball 14K7r. There were some other oddities like a 15n film capacitor and two 2N3919 transistors and the 2N5485. I also was all out of BC550c transistors so I used three BC550b in their place (lower DC gain than c). I used a 125B Enclosure from Gorva Design C65. If you never worked with these, it is a precision made box and it is deep. The Gorva C65 that I used was powder coated in silver sparkle. I applied a traditional waterslide and sprayed the entire pedal with Spraymax 2k clear. settled on these 21mm white knobs from Love My Switches - in one picture you can see what it looks like with gold Davies 1510s... they seemed off to me. I used Lumberg jacks and a hot pink soft click footswitch. I used a 3mm orange led with a clear freznel.
The board is laid out well and I enjoyed the build. If you like distortion and fuzz you should build one.
Notes
