C2C troubleshooting ?
Audandash
So how do you guys troubleshoot c2c projects? I am afraid I am going to blow myself across the room with voltage, lol. I have been lucky and only had 1 c2c project not work right off the bat and I am scared to probe. I just ordered the board again and I am going to rebuild it. I never really got into amps for the same reason. I just have a healthy fear of voltage and dying. I guess to be clear is what I am asking for is best practices when probing these circuits, just in case I do decide to ever trouble shoot this board.
Good, that's what I like to hear. Always respect the electrons and understand that they can kill you, and as long as you remember that, you'll be fine. We're orca trainers here; when we work together with the terrifying deadly creature, we can do really cool things. But we have to respect the fact that the orca can kill us at any point. Just don't let that fear keep you from getting in the water (weird analogy I know, but my kids are into sea creatures so it's on the mind).
The vast majority of troubleshooting should be done unpowered. Anything that can be checked visually like soldering (checking for bridging, cold joints, etc), component values, component orientation, etc. should be the first step. If everything looks good there, then it's time to poke some voltages.
For most circuit I advocate "rock before you box", but for tube pedals I generally recommend putting the board in the enclosure as it's much safer to troubleshoot when everything is securely fastened to a box.
The "One Hand Rule" is always a good idea: never have both of your hands on/in/around the pedal at the same time when it's powered up. Personally I like to keep my unused hand behind my back just to make sure I don't accidentally bump something. Clip-style leads for multimeters are wonderful for this as you can clip one onto the chassis or the 1/4" jack sleeve and just use your one hand to hold the red probe and poke things one at a time. If you don't have a clip lead, one thing I do a lot is to stick the pointy tip of the multimeter probe in one of the enclosure screw holes and let it sit there as my ground connection for voltage measurement.
The first place you'll want to poke is the positive VIN, I usually poke right at the connector. You should be getting 9V or 12V, whatever your supply is. If it's significantly less, either you have a short somewhere or your power supply can't provide enough current for the circuit.
If your VIN looks good, the next thing to check is the scary one, your B+ rail. I typically probe this right on the cathode of the UF4007. The actual voltage you should see here will vary based on the circuit, your input supply, and what tube(s) you have installed. If you're seeing 200V or more, your SMPS is good. If you're seeing a lot less, especially if your B+ rail matches your VIN, then there's a problem with your SMPS (forgetting to install the NE555 is a common cause for that).
Obviously I hope you never need to troubleshoot one of these circuits and everything works first time, but if you do need to troubleshoot, I hope something here helps.
Thank you for the tips. The circuit I am referencing is the mirage tremolo. The volume and tone work but no tremolo action. I already have another one 95% built I am just waiting on a few pots. I have done all the visual stuff and am down to the nitty gritty voltage stuff. If I do decide to troubleshoot I will post it in the troubleshooting forum. Thanks again.
If you are really worried then wear some insulating gloves for added safety, just the normal everyday rubber kitchen gloves will do but if you have some disposable ones like medical people use they should be ok as well and they fit better. You can also stand up and wear some insulating shoes like gumboots or any sneakers with a plastic bottoms, they should also help insulate you from electric shocks, electricity is harmless if only one end is connected to the source. Birds can sit on 110,000V power lines and not be affected because they are not touching anything else, if 2 birds sit on separate wires and flap their wings so they touch they are instantly cooked because they complete the circuit. Keeping one hand behind your back is very good advice for anyone who is not trained to work on electricity, even people who are fully trained electricians get electric shocks when they work on live equipment so excess caution is always advised.
This is a good article on how the tremolo circuit works, if you redraw the Mirage Tremolo you will find the timing circuit looks and works like this article. It might come in useful in fault finding your build.
After reading the article I figured one of the tubes was the likely culprit. Well I got the new board and built it anyway while waiting on new tubes. I had the same exact thing. Volume and tone work but no tremolo. The only thing I kept the same between the two was the tubes. I swapped them out for a new apex tested set and it worked. So now I have two tremolos, lol. This is another PSA for buying tested tubes. The first round of tubes was from my last batch of untested tubes. It’s worth paying the extra $2 for tested tubes. My c2c/sushi box builds still stand at 100% success the first time. Woohooo.
Excellent, that's always what I want for people. Debugging skills are important because eventually something will go wrong, but part of "design for manufacturability" means making it as easy as possible for the builder to succeed, and that's always one of my goals. A person with an engineering degree should be able to design something that can be assembled without needing an engineering degree.
I just finished mine up, have had zero fails so far with C2C stuff and same result. Now I'm concerned about the tubes lol
I'm pretty good at debugging at this point, and have looked into this forum and tried swapping tubes, still same result. Tone and volume work, just no trem. Any ideas where else I should start? going to reply with a picture (not solder side, I haven't taken it back out of the box yet lol
