Champ Amp 2 Prong Replacement And Others
joelorigo
I have my father-in-law's 1966 Fender Champ amp. At some point the original 2 prong was replaced with another 2 prong. I have been wanting to use my pedal building experiences into building an amp someday and I was thinking about removing the "death cap" and replacing the current 2 prong cord with a 3 prong cord, and maybe some other things might be a good way to start. I was going to start with a tweed Champ or Deluxe kit but I don't have the money right now.
I have seen Psionic Audio and Uncle Doug videos about old Champs and they are also talking about replacing the "bias resistor" with a higher value to compensate for modern wall voltages. Changing the "mids resistor" to combat the inherent boxy-ness. Replacing the "filter cap" and "cathode caps." (BTW I know what these things are only because of the videos mentioning them and pointing them out were the are on the turret board, lol) Replacing the SPST switch with a DPDT. I was also thinking of replacing the RCA speaker jack with a 1/4" to make it easier to use external speaker cabinets. Really I just want to replace the power cord first so all these other things could come later. I also have a 1975 Fender Bronco so I would think all of this would apply to it as well (although it has a 3 prong cord already).
Do any of you with amp building experience recommend / agree with these mods, and have good resources you can share?
1. 2 prong to 3 prong and remove death cap — yes, very much yes.
2.
Bias resistor? Maybe. You’d have to check what your voltages are inside the amp (SAFELY OF COURSE) to determine if you need to adjust bias. BUT, the 6v6 is pretty robust.
Mids resistor? Maybe, but that’s the charm of Fender amps
Filter caps? Maybe, depending on age. If the amp hasn’t been played in a while and has some buzz, might be necessary (get good quality but don’t overspend on super fancy).
Cathode caps? Not likely, replace maybe. Again, changing the value will change the voicing.
1/4” plug/jack for external cab? Heck yes
3. Reading material —https://robrobinette.com/Amp_Stuff.html
2.
Thank you!
Thinking the bias resistor couldn't hurt. Friend of mine uses a 60's black panel Princeton reverb with this little gizmo and has made a world of difference. Brown Box .
Reviving this because I finally did something with this amp.
I have removed the death cap and 2 prong plug. I installed the 3 prong but have a couple questions.
I have the black wire attached to the fuse. I have the white wire attached to the on/off switch. I have the green wire around one of the power transformer screws and clamped in by the nut. The amp works but the jewel light doesn't come on. Is this because it is not grounded anymore as one end of the death cap was attached to it?
Probably more importantly are the black and white wires correct above? Claude and Geminii told me to do it that way but now Claude says it is safer to reverse it.
DO NOT listen to Claude or any AI slop generator as they will confidently tell you utter bullshit. You are playing with mains that can and will kill you if you don't know what you are doing (which it appears you do not).
There are numerous guides out there from experts which show you the correct way to wire up the mains input to an amp.
Just guessing your way through it is asking for a catastrophe.
I believe in the USA the colour code for AC cables are black = hot, or active, white = neutral and green, green & yellow = ground. As it comes in from the power point black should be wired to the fuse and from the fuse to the on/off switch. White should be wired directly to the neutral or "zero V" winding on the PT's primary. These days a lot of amps switch both live and neutral with a 2PDT switch which is the better way to do it but in older amps the way I have described it is to code and safe.
The next important thing to know is that the ground wire on the AC cable must be longer than the other two. This is to make the ground the last thing to become disconnected in the event of the cable being pulled out of the amp. The ground wire must have its own connection directly to the chassis - it must not use a grounding point shared by anything else. And it is best that you DON'T solder it to a ground lug secured to the PT mounting bolts. Keep the ground for the AC cable away from everything else - usually it would be soldered to the chassis quite close to where the cable enters the chassis.
The "green wire" - I just had a look at the Fender AA764 Champ layout diagram and see that Fender grounded one end of the filaments. That means that you should have one green wire from the PT soldered directly to the chassis and the other end to the pilot light. The pilot light should be grounded to the chassis and the death cap should have nothing to do with it. Make sure that the nut holding the pilot light is tight and that the connection of the pilot light assembly is clean, because the pilot light is being grounded by being bolted to the chassis.
Oh, and @drew.spriggs is absolutely right!
