Fixing up an Ibanez TK999HT
Stickman393
I've got this pedal on my bench right now. Picked it up cheap because it was broken.
Someone clearly used the wrong power supply on this thing at some point: there's a little step-up, dual voltage transformer in there, and the primary reads as a short. Like...more of a short than would be typical. Barely any voltage on the secondary.
Soooooo...I need to figure out how to replace this little thing. Easy enough if I can figure out what voltages it originally operated at...but I need to use the schematic in order to find some clues.
The original power supply was a 12vac. From there it goes directly to the primary coil of this little "TUBE-A FEDERAL" transformer. I do not believe I'm going to be able to find a direct replacement for this thing, so I have to improvise.
Looking at the schematic, and from what I've read online: it's a step up transformer with a slightly higher voltage tap and a much higher voltage tap.
The lower voltage tap goes off to a 33 ohm resistor to the tube heater filaments (I imagine in series, though I'll double check) and a 78L12 12V regulator. The higher voltage tap goes off to some kind of poor man's half wave rectifier/ 96vdc regulator. So...my first assumption here is that the first tap is in the 15-18V range, and my second tap is in the 100+ volt range. Could one of the electrical gurus here double check me on that?
IF THAT IS THE CASE...then I have the following that I'm kicking around as an idea to get this thing working again:
Let's just say I run a single 15-16VAC wall wart transformer, probably around 2VA, into the pedal, using that for the low voltage section.
THEN, I would use something like a 120/20VAC transformer wired in in back-to-back configuration, with one leg on the primary and secondary jumped to create a common leg between them. That *should* induce a roughly 100vac potential on the primary, right?
It seems like this should work? Sharing a common leg certainly works for autotransformers, but maybe I'm missing something...after all, it it was that simple why wouldn't ibanez have just done that to begin with? That said: I see 120Vac/24Vac all the time at work with one leg of the secondary bonded to ground...by code, neutral is bonded to ground as well. Wouldn't this be essentially the same thing?
My goal here is to recreate this dual-voltage step-up transformer with as few parts as possible.
Before the warnings, yes I understand the dangers of working with these kinds of voltages and yes I understand how to do so safely. I fuck around with 460Vac on the regular at work. But...I would appreciate some educated feedback, as this is starting to get into an area where I have questions.
Schematic attached:
Hey, did you menaged to replace the transformer? Still no info on the web.
I have two of these, use them in stereo, yet would like to replace the stock transformers to Uber toroidal shielded and epoxy potted to reduce the noise of the unit, yet local company require me to give them values.
I might hire someone to measure it if you don't have them either.
Wondering if going with power banks with a step up converter and an inverter would reduce the noise even further.
Haven't gotten around to this yet...but got more information.
This kinda required me to learn a bit more about power supplies...which is actually helping out a bit with my concurrent CNC build.
So...as far as I can tell, this thing is operating with two voltages: 96vdc, and 12vdc. The tube heaters are from an unregulated power supply, straight off the smoothing capacitors. The majority of the circuit operates off the 78l12 regulated 12v, and the plates are fed by the 96v circuit.
So...I'll need to do some calculations RE: ripple, but it seems feasible that one tap of the transformer is basically 1:1, the other is...well...don't quite know yet. I can probably have a better idea with a little math. It's certainly going to be below 160v, given that's the rating of the caps in that portion of the circuit.
I haven't been able to actually use this thing, so I can't comment re: noise, but it certainly seems that there are a few things one could do to reduce noise in this thing...if one was to move to an external power supply.
I've thought of doing this and using a circular, aircraft style screw-on multi-conductor plug, doing all the rectification, regulation, and most of the filtering in an external box.
Granted, this is just my current assessment; I'm trying to broaden my knowledge. I've already had to revisit a few faulty conclusions on this one.
Well, I modeled the power supply for the tube plates in an Android spice-like-program.
This screen capture confirms my suspicions that the plates operate at 95ish vdc, and supplying somewhere around 115vac to that portion of the circuit should do the trick. Best to do this off an isolation transformer or in back-to-back configuration, though. Current limit that shit. Dangerous voltages ahoy.
The second part of the circuit...is likely in the 16vac range. Just judging by my little mock up circuit, and using a 150ma current source as a stand in for the tube heater. That's assuming that the heaters are in series, something I haven't confirmed yet.
The heater circuit seems like a clear spot where one could make an improvement. Lots of ripple there. Hell, I could be making assumptions here though...this is my first rodeo with this program.
Buttt...I'm thinking that I've got an idea of what I ought a be seeing on the secondary now. The conductors on the transformer should be 16vac, common 0v, 120vac.
I could get a custom transformer made...but I'm thinking I'm more likely to rip out the internal PS and use an external module with a 4 conductor plug. I'll be able to filter and regulate the power I feed into this thing and deliver much smoother DC.
  • Like
Reactions: fig
Hey, did you ever find out a fix to this? I have one too, looks like maybe same problem. Someone used a 12v dc input.
There's really no like for like replacement out there.
BUT, a small 120vac to 12vac transformer will work. 5va is way more than enough to power the B+ circuit and should fit. In truth, you're likely to be safe with anything over 0.5VA. Assuming 1ma draw per triode x2.
The trick is to wire it in reverse: power the secondary with 12vac from a wall wart to get about 110-ish on the primary side. Once you connect to where the old transformer was it'll go through a half-wave rectifier and regulate down to about 98vdc through a big transistor and zener assembly.
You'll also have to wire the 12vac coming in from the wall wart in parallel to the heater circuit. That goes through a bridge rectifier and regulates down to about 12ish volts. Hopefully closer to 12.6 in operation.
The original was a two in one transformer: an isolation transformer for the 12vac input to 12vac output, and a step up transformer likely around 100-120vac. The 12vac powering the heaters doesn't *need* to be run through an isolation transformer, though it might be a touch noisier afterwards. And that 12vac transformer powering the circuit absolutely cant have a grounded leg on the secondary.
I've been meaning to get to this once since I've been learning more about teh tubes and such. Only thing holding me up right now is I can't find a few of the pieces for the tube assembly, because I am in actuality a trash panda.
Hoping I can find those soon. Would love to get this thing back together.
I'm definitely going to be swapping the barrell connector on this fucker in favor of a small aircraft variety though. Just to make sure nobody ever plugs in 12vdc again.
Damn. I think that puts it out of my ability level then. I can follow a schematic for the most part but I can't innovate like that yet. I'm still a baby pedal builder. Or a teenage pedal builder at most. I was hoping to make a vero layout for this monster rather than buy one but I think I have a ways to go before I can figure that one out - if it's even possible.
Just a quick update here:
Ok, so I found some of the parts that were laying around. I replaced a bunch of the caps on the board (particularly the electrolytics, cause this thing is old enough to justify it)
This is the transformer that I picked out for this particular rebuild:
1.1VA, little math:
1.1va/115v= about 9.6mA before losses.
The 12ax7 shouldn't need much more than 2ma from the B+ line, so we should have plenty of headroom. Granted: the AC current feeding a rectified DC circuit can be higher than the DC current demand, so it's good to have a little bit of room here.
The only purpose of the transformer is to step up voltage for the B+ line. The schematic doesn't make this completely clear, but I'm going to have to connect one leg of the "secondary" (which is actually the primary) to DC ground in order to complete the circuit.
This is gonna get strapped down to the enclosure via the original mounting holes, just a little plastic strap will do the trick. It fits pretty well!
Its a 12.6/6.3vac secondary transformer. I'm going to tie the two secondary windings in series and feed my 12vac input to the "secondary" (which is now going to be the primary) in order to induce about 115-ish volts on the "primary" (which will now be the secondary). A little back
Then, 12vac will also feed the rest of the circuit. 12vac input is run through a bridge rectifier, smoothed, and branches out to both a 12vdc regulator and what should be a 12.6vdc heater circuit for the 12ax7.
I just gotta make sure I got everything connected properly. So...we'll see how this goes!
A'ite, I'm not one to just cowboy shit. I like to sit back and think about how everything is gonna interact. So...I came to the following conclusion:
It looks like the original return path for the 115v to B+ circuit runs *through* BR1, back to terminal 4.
Which creates an extra little wrinkle. Something I might need to consider:
Did Ibanez design the original transformer with the windings *in phase* or *out of phase* with each other? Does it even matter?
Nothing uses the full summed voltage of the secondary. I imagine the way this was originally designed was out of phase, reducing the total voltage across 3-5, but its something I have to chew on a bit.
Then again: I could always simply isolate each part of the circuit. Nothing here says I *absolutely* need to keep the existing topology. I could simply pull/jumper the diode + add a bridge rectifier for the 115v circuit side. Tie both resulting negative ends of the same point, viola.
Probably need to swap the 100uF/160v cap in there too. Its got about 25mm of clearance, and 160v is gonna be too close for comfort when compared against the actual rectified unloaded voltage this thing is gonna see. 200v would be better.
Its funny: I'm reading back my old posts from 2022 and am like "nah brah. Wrong track. What a dummy"
Time makes fools of us all.
OK. So I'm settled. Unless somebody comes in and tells me that I'm full of shit. Which is possible.
I'm gonna completely separate the two AC supplies. No common leg. The 115v secondary will run through a bridge rectifier, and the resulting DC legs from the 115v and 12v rectified sections will be joined at their negative poles.
The full wave rectification of the 115v secondary will result in lower ripple, cut down a bit on noise, and will make better use of the transformer (conducting on both sides of the AC sine wave will spread the current draw out across both the positive and the negative cycle, instead of exclusively conducting on the *positive* cycle. Lower, continuous current at a 120hz ripple rather than higher current draw at a more dramatic 60hz ripple).
I'm gonna grab a 200vac capacitor to swap out C3, keeping it at 100uF.
I'm gonna end up slapping one of these on the power input and modify a wall wart to use the plug. Let's see some motherfucker feed 12vdc into this thing after I do *this*. 1000059462.jpg
