PedalPCB Nice Ball Overdrive/Marshall JCM900 Overdrive Pedal 125b
OD is Glorious
4.00 star(s)
Is this an overdrive or is it a distortion pedal? Both is the answer. I noticed that rolling the gain down you get almost no sound. The volume alone will bring you no headroom. All knobs at noon - below unity. Volume needs to be at almost 2pm before you get above unity, but cranking the gain will bring up the volume and the saturation and you will have headroom. The tone knob works as you would expect. The contour adds something in the tone that I cannot identify: to my ear It seems to fine tune the mids? The texture of this circuit's saturation is great, but maybe a bit thin? So what to call this circuit? They print distortion right on their pedal, but they call it an overdrive. Perhaps because overdrives get more $ and attention than distortion pedals?
I followed the build documents and pcb's silkscreened values to put this together. Thank the heavens for the PPCB Auditorium platform because my build had two issues. I missed a film capacitor (see if you can find the missing cap in the pic). After I added the cap to the circuit still did not operate so looking agin - I had an incorrect op-amp inserted in the TL072 spot. If I had boxed this without testing on the PPCB A.P. it would have been frustrating work.
This has a high parts count build (63) and the only oddball parts are a 2N7 film cap and perhaps the MC33178 (PPCB has the op amp). I put the circuit in a Tayda Lavender colored 125b. I added a film free decal and a 2k clear coat. I used a PPCB top jack plate and enclosed jacks. The knobs are white Davies 1510s and the LED is a green diffused 3mm without a bezel (1/8" hole). The footswitch is a soft click with a PPCB breakout board.
It is worth building IMO - but four stars
Notes:
  1. You might consider a different value or taper for the volume potentiometer. All the volume above unity occurs after 2pm.
  2. 2N7 film cap needed
  3. One MC33178 (PPCB has them) you need to mount it on male/male pin headers
