This overdrive picks up where my previous build, the Glory Hole leaves off. That's both in terms of the available gain, and also because they were built as part of the same batch. This build once again finds me "catching up with old friends" - that is, it's part of my project to drain my queue of PCBs I've acquired over the years.
I've always seen people refer to this drive as a "Rat for people who don't like Rats". I don't have a Rat on hand to compare against. A quick look at the circuit shows that the main similarity is the hard clipping, and the classic three-knob controls (volume, drive, tone); and the tone works in "reverse", i.e. as a hi-cut. But lots of other obvious differences compared to a Rat:
So IMO, it's more different to a Rat, versus say a Jan Ray is to a Timmy.
This actually didn't work on first power-up. It turned out to be a bad trace, and is causing me to question my assembly technique. Easily fixed, you can see the little jumper I soldered to the back in the pics below. (You can also see the 390pF cap that I soldered to the back, since it was too big to fit on the front.)
Sound-wise, I only played with it briefly once I got it working, but it sounds pretty good, better than I expected. It's smoother-sounding than I expected from a hard clipping circuit, and there's a really nice range of dirt, from clean boost all the way to upper-mid gain. 18v buffered bypass is a nice feature too.
Like my recent Glory Hole build, this is from my first batch of enclosures finished with SprayMax 2k. It's the matte version, which I think makes the bare aluminum and minimalist graphics look a little dull. But - at least it won't glare under stage lighting or sunlight!
- Integrated boost converter for 18v operation
- Buffered bypass (should be easy enough to wire as true bypass, if that's your preference)
- Legacy, externally-compensated single opamp (LM308, OP07) replaced with modern dual opamps (TL072)
- Original JFET gain recovery stage replaced with opamp
- Filtering at the clipping stage is different
