xefned
I'm still debating the idea of making a small batch of PCBs for the Weber stompbox transformer with 9 secondary windings.
If I were smart, would I share the ground plane among all 10 PSUs, or give each PSU a separate plane?
I found a debate where both methods were criticized, at least hypothetically, with no real conclusion.
My hunch is that fully floating grounds will eliminate the possibility of hum through shared grounds. This is how I've always run mine. Any other thoughts out there?
RG Keen's Spyder design seems to imply floating is better. Scott Swartz seems to do it this way too at his GGG project. Same situation with the layout at Geofex. Still, I can't help but worry that this is somehow problematic. I don't own a commercial unit to open and see how the pros do it.
