2 Effects Controlled By a DPDT Switch?
BuddytheReow
Moderator
I've built 2 small effects that I want to put into a 125b box. I've already drilled the box from a previous project that I scrapped. What would be the best way to wire it up so that I can switch between each circuit? Would a DPDT toggle switch work? I would wire up the in/out of each to the switch and the main in/out back to the 3pdt stomp switch. I don't think I have enough room to put an additional 3pdt switch in there. Both units, I guess, would be powered on at the same time. Is this possible or would it create issues?
