Caldo71
Regarding this from the Wiki...
wiki.pedalpcb.com
I was just curious as a newbie builder what the electrical theory is behind the seeming fact that you can power two builds from the same 9V power supply? Which assumedly is the case, or that diagram would not exist.
I guess as a novice it would seem to me that those 9V would only be enough to make one of these miraculous gizmos run, and that they'd "run out of juice" if you try and hook up more than one to the same power. Obviously I'm wrong. So how does that work: does it have something to do with how they draw amperage? Bear in mind I know next to nothing about how current works. Talk to me like the dummy I am ;-)
And that leads my brain to the next illogical question: is there some alternate version of this same wiring that could power several pedals (like four, eight, whatever) if they were in the same huge housing? Or is there some kind of practical limit?
Sorry if this is all reeeaaaly f%&*ing dumb: I'm learning...
![wiki.pedalpcb.com](https://wiki.pedalpcb.com/images/4/42/2-in-1_Single_Switch.jpg)
2-in-1 Pedal Wiring (Single Footswitch) - PedalPCB Wiki
