2 One-Knobbers in a 1590b?
BuddytheReow
Moderator
So, I've got a few 1590b enclosures lying around and am looking to give them some purpose to their dust collecting lives. Is it possible to fit 2 one-knob fuzzes with one volume knob, and a switch to select between each? One of them may be a two sticks of Derm and not sure about the other one. They'll both likely be stripboard layouts.
Should be able to. It’d definitely be easier if you put the two into one strip board layout.
Are you asking about space or using the same volume pot for both?
1590b is a tight fit. Here's a photo of a belton reverb/sho I built. It's in a 125b. Both circuits have been in and out of previous builds, so the wires are a mess.
To help with space, the switches are angled. And the pots are off board. I hope it helps.
It's always fun having two in one.
Both. I think I can use a spdt on the output of each circuit to switch between the two. Dpdt if I want to have LED indicators. I’m more courteous if all this will fit in those deceptively small boxes
