I JUST asked @Robert the same question. I'm planning to build it but I'm not exactly sure how I'm going to use it.Anyone built one of these yet? If so, what are you using it for or plan on using it for?
Is it similar to the EHX Parallel Mixer or is it something entirely different?
I plan for the same with a few mono tape players I recently repaired. Most of my weird sound sources are mono.My interest in the mixer is for synths. I have an affinity for bleeps and bloops, and having a simple mini mixer to blend in and out different noisemakers in a tabletop setup is tons of fun
I originally was going to buy a Red Panda mixer, but I'm building this 3-channel mixer, now.Anyone built one of these yet? If so, what are you using it for or plan on using it for?
‘CrabVerb’I’ll just leave this here
I hadn’t seen that till now! I freaking love that build!!! Amazing!
You could just buy 20$ Mosky EP Booster clone off Amazon. It’ll reverse the phase and you’ll have an EP Booster.Gonna feed 3 of these into a 4th and run all the the YATS at once. View attachment 55818
But seriously wish this had phase invert capabilities.
Anyone come up with a semi elegant solution to patch in a dpdt across the +- inputs?(I think that would work)
Or maybe I should be proactive and just build inverters into every pedal that inverts the phase.
