untamedfrontier
Abider build and my first attempt doing anything with SMD soldering.
I learned some things! I definitely have room to improve on technique (not surprising), as the first J201 I tried (and pictured below) probably needs to be re-centered, as I don't think it's got a solid connection. It also doesn't fit in these sockets if you use these right angle pins, so that may have been an issue with the first one i tried. 2nd one I just used resistor legs, and I put some electrical tape over it because I'm paranoid.
I also used a 470n box cap instead of the .47u (or 470n) electrolytic cap as mentioned in another build, and that worked totally fine.
You can't see it in the pictures, but I did use a ribbon cable for the connection to the 3pdt board, and I tried out a power connector, which was a bit of an adventure deciding how to best get that oriented. Props to the other threads where these connectors were shown.
Today's build is brought to you by Jenny Lewis' 2019 masterpiece On The Line
