Tha’ToneSeaQr
Hey guys! I’m interested in building a buffered effect using the simple Jfet buffer pcb offered here. I’m wondering how you would wire it up adding it to the off board components/main pcb. I imagine that you could just run two leads from the main board.. One set of leads to the switch, the second to the buffer pcb?? I’m not sure
There’s also the matter of the placement of the buffer either pre/post circuit, as well as the possibility of maybe using an input and an output buffer.. Or would 2 buffers be overkill?? I’ve always been curious about how a buffered circuit would change or possibly improve the sound of my overall sound (I’ve got a bunch of true bypass fx wired in single chain).
I’m thinking it would be cool to build either the Katana boost clone or the “Clandestine Pre” ep-3 with an added buffer.. Thanks in advance for any help or advice!!
