Just built this pedal (Cornish P1 clone).
It bypasses fine (and I have it set to the have the buffer on so I assume that is working ok). But when I turn it on I get almost no sound. LED lights up but barely audible.
It’s a poor build (think my brain is also on holiday…) but before I rewire the whole thing again, I thought I would see if anything jumps out as potential issues / solutions.
Issues that I thought about but am not sure whether they will be causing this are:
- exposed wires where they join the foot switch PCB (I could probably add some solder there).
- output wire is quite tight (I didn’t cut it long enough).
- I forgot to clip the pots and toggle switch after I soldered them onto the pcb so the ends of the jugs slightly stick out from the solder.
- wonder if I fried the power jack. I couldn’t get the wire connected and the solder iron slightly melted a little bit of the plastic.
- on the power jack the solder from the lug to which the green wire is attached slows down the lug and touches the yellow plastic section. I didn’t think this would be an issue as it’s not touching any other lugs of the jack.
Thanks!
Thanks!
