Ctrl4Smilerz
Okay, so I just got my Aion double pedal boxed up. Refractor (Klon) and Achilles (P.O.T.) with an order switcher. Achilles side works and sound great, but only works if the order switcher is on it's side, if not I still get bypass sound. The Refractor gets sound in both bypass and engaged. It produces a high pitch squeak if I turn the gain past 12 o'clock , and gets a heavy hiss if the tone is turned past 12 o'clock. I used shielded wire for all the signal carrying cables.
Here is the gut shot (Refractor on the right):
Here is a video of the squeak:
And here is the wiring diagram I used to wire the switcher:
I reflowed all the pots, the send/return cables, and reseated the ICs and diodes. Any help in debugging is appreciated. TIA
