Fama
For whatever brainfart reason, it seems that I ordered 470nF MLCC caps for the Arachnid instead of 1uF. Would I be fine using those, or should I just wait until I can get more 1uF caps? If it helps, I can use 1uF for C6 and one of C10 or C3 mostly easily, the others would have to be two of the 470nF caps which gets messy and a bit trickier.
From what I can see they're coupling caps (plus the input cap is only 100nF), so I assume 470nF should probably be just fine, except for the one cap that comes from the FV-1 into ground instead. But I could put a 1uF for that since it's C10.
However, my electronics knowledge is still spotty and horrible so if anyone knows better, I'm all ears.
For easy access: https://docs.pedalpcb.com/project/Arachnid.pdf
