southpaw-dd
- Build Rating
- 4.00 star(s)
I've got the Friedman version of this pedal which is a favorite for boosting the front end of my Dirty Shirley Mini tube amp. If the drive is set higher on the no diode or LED modes, it can get grainy and has an unpleasant note decay. Much better for pushing level without much drive/clipping. The diode voice does sound pretty good, but not my favorite drive for that purpose.
The real pedal sounds a bit sweeter in the mids than my build, but it is pretty subtle. I'm going to change out the LM833N to see if another op-amp makes any difference at all.
My first attempt at the Tayda UV print was a fail - I had reversed the voice and hi-cut sides on the front panel. This is the Metallic Light Gold enclosure color, with black UV print and matte gloss layer on the black printed areas.
I like using the pre-bond ribbon cables from Stomp Box Parts for connecting the 3PDT board to the main board.
Overall, an easy build and sounds good for low gain boosting or medium gain boosting in the diode voice. The high cut feature is nice and something I'd like to see on other pedals.
