Bass 6-Band EQ?
ShaneAngelRiot
Will there eventually be a bass 6-band EQ PCB or maybe in the same vein as the Muffin Fuzz where there's a separate list of parts to assemble a bass version?
The 6 band EQ is just a set of gyrator filters. You can use a gyrator calculator to figure out values for whatever frequencies and Qs you want.
As mentioned above, you just need to change a few components to change the frequency bands. I do think it would be a great idea if, since the faceplate is printed on both sides, one side has the stock frequencies labeled, and the other side had the bass eq frequencies labeled, so you could use the same faceplate for either version
So if I just change the values of the certain capacitors I'll be able to change which frequencies I want each pot to effect?
Caps and resistors. Do you know what frequencies you'd like to see on this? I think I kept notes on how I changed the frequencies on mine for guitar.
Check the math but this might get you in the ballpark:
BASS
55Hz
C5470n
C61u
R1118k
R101k
110Hz
C7150n
C81u
R1324k
R12
470​
250Hz
C9120n
C10470n
R1524k
R14
300​
560Hz
C1139n
C12220n
R1722k
R16
470​
1.5KHz
C1318n
C1468n
R1920k
R18
470​
3.5KHz
C1656n
R20820R
