Best Clean Fender AIAB
Thanks dude, I’m just not looking at going that deep with it. I’m basically looking to do my own version of the Crazy Tubes HiPower.
If that’s the case you want a power booster and hiwatt style circuit. The Aion Fx ST-2 is supposedly Cornish take on the powerbooster. It’s a lot cleaner than other PB circuits I’ve tried.
Cool, just riffing on my usual workflow. For clean stuiff I typically would start by modeling the actual original tube circuit in LTspice, then look at impedance scaling to an opamp circuit as appropriate. The only guitar AIAB tangent I've really worked so far outside of many Fender bassed ones was Dumble oriented, and all three I've built so far are radically different from each other. That's not necessarily such a bad thing though!
For my wants and needs Hiwatts have gotten my attention more as a bass thing, and in my case using a DR103 output transformer clone with 4 x EL-34 worked out really well for me.
Thanks for your input
The Aion take on the Lab Series, the Lab Series Preamp Clean Channel is a Black panel inspired preamp. Bonus Robert Moog compressor. It's a tad spendy for parts but I think it's right up your alley and totally nails what Moog (Gibson back then) intended to be a Twin killer. You can use this beast to drive a power amp as well should you decided to use it as the front end of a rig.
Thanks dude - I think we have established that you are far more talented than I !!!
Nah, not my intent at all. But in any case, I'm definitely interested in expanding my tone stack horizons and Hiwatt looks well worth some investigation. I have my model for a stock DR103 up and working now, and will do a proper build thread once I decide on whether to go with tubes or opamps.
If you go with opamps that can be adapted to pedal format easily.
