Could I use a 4 way selector or 2 on/on switched so I could have them in the outside of the encloser in place of the internal dip2 switches?View attachment 82911
Order today, ships today. M2011S3A1W03 – Toggle Switch SPST Panel Mount from NKK Switches. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
www.digikey.com
Will need to check the pin spacing vs the datasheets. Here the narrowed down search on dk @Dirtymojo83
The spst switches with 4 legs may work even better as you can clip the outer legs and be able to place them side by side. Just make sure you get threaded ones and again, datasheet.
