British Royalty Overdrive w/treble boost
Cvp1969
Hi. So- I am doing a British Royalty overdrive and I’m adding a perfboard of a V806 treble boost. I breadboarded everything from the schematics and got it working. I did the perfboard and loaded the PCB of the British Royalty. Now I am thinking just how to wire it up with a single 9v power supply.
On my breadboard version- the guitar hits the treble boost first then goes to the BRoyalty. I wasn’t thinking ahead and I used two separate power supplies. When I wire this up-I’m thinking of running the power to the treble boost and running a line to the power input on the BR. Then running a line for ground between the boards and to the ground terminal of the power supply plug. But I think this might not be the way.. this is just my initial thought right now. And ideas/experience?
I have the wiring diagram for a two footswitch pedal..
Am I on the right track?.
