Building for a pedal for tour
Our 3d printers had heads that a long ribbon attached to, which moved around like crazy. After about a year (of probably 8hrs per day) I began having weird print failures that I de idea were cable issues. I found (pretty sure it was Mouser) some mil spec silicon ribbon cable, and bought enough for all the printers. That was 7 or 8 years ago, and I think their still going strong.
I'd love to see some mil-spec cable in the flesh, see how it compares to the weak civi-stuff.
For various reasons, some already mentioned in the thread, it probably still wouldn't wind up in my pedals, but if my printer needed repair...
IIRC, the only time I've used ribbon-cable was... hmm I vaguely recall using it once, but can't remember for what. Might've been a repair of a pedal that came with ribbon cable.
Other thing to consider (that goes somewhat along the modular stuff): use offboard wiring for the 3pdt and jacks, if you go all onboard your PCB will eventually fail on the points of most mechanical stress. Using offboard wiring for these parts leaves the mechanical stress just for the part itself and it’s much easier to eventually repair. And I HATE those socket things and ribbon cables to connect 3pdt, I lost account of how many I had to sub because the wires broke and/or the contacts got bad
Use some Electronic Grade Silicone, strategically placed droplet sized blobs, to secure longer wires to the enclosure. Great for controlling vibration and mechanical shock related failures. Using small blobs makes future repairs/mods much easier.
Also good for securing components into sockets, again using 1 or 2 small strategically placed blobs after the component is installed. Properly done you should be able to remove the droplet sized blobs with some needle-nose pliers if you ever need to remove the component.
There is a balance between serviceability and robustness of the build. As illustrated by the fact that one could, in fact, simply epoxy the whole damned thing as long as one accounted for the spring movement of jacks and the space requires for plugs.
But even then, certain devices might suffer from thermal issues. Dunno the R value of epoxy in general.
The most robust way to build a switching system for a pedal would probably be a solid-state FET-based buffered bypass with a high quality momentary switch. Lehele makes one that's supposed to be rated for a million cycles. Also: there are plenty of long-life rated tactile switches out there that you can use with an external, spring-loaded plunger. That takes some engineering work, though.
Thinking about this...honestly, makes a lot of sense why so many old pedals were built this way. Particularly when cheap and robust multi pole stomp switches were less prevalent.
Relays would be a close second to solid state switching. 3PDTs are fragile little buggers if you've ever opened one up. A few bent metal tabs, plastic, and levers. Anything gets fucked up, and the whole mechanism breaks.
The rest...well...
Try to mount your potentiometer knobs with as little space between the enclosure and the bottom of the knob as possible. Somebody steps on one of those, and if there's too much travel it'll push the shaft straight through the bottom of the pot.
Free-wired jacks can be relatively robust, but also remember that if the nut comes loose you might have somebody twisting that son of a bitch for a *long* time before a wire eventually breaks. So loctite is not a bad idea there.
Wire neatly with straight runs onto your targets to avoid excess strain. The idea with electronics grade silicone is a good one.
